Problem to draw 2D graphs in ptc mathcad
  • May 17, 2021
  • 2 replies
  • 3364 views
Hello friends, I have to calculate a beam on elastic basis by the finite element method for my master thesis, I do not understand why there is an error for plotting the graph.I attached the file.Really need help because the deadline for submitting the thesis is Friday, May 28
Best answer by AngericoEric
I've missed one square brackets , now it worked thank you Luc.
God bless you!
Angerico Eric
Each value of M(x) for a value of x that you are trying to plot is a 1-element vector. You cannot plot that way.
If you extract that element, it should work. The simple remedy should be: append
[ORIGIN
to the M(x) in the plot, this 'll take the first (and only) element of the M(x) vector.
But a better way is to prevent getting vectors as results for M(x). I see that v(x) also produces arrays. Haven't tracked back further.
Thank you Luc for you response,i'm new to mathcad prime and i don't understand clearly that you've said but if you can give an example, i hope that will understand.
Y've changed all square brackets to round brackets Luc but i've got the same error in the plot and i don't know what is the problem now
Enclosed is an analysis called "winkler springs FEA" that gets a moment distribution.
Cheers
Terry
