This is what I could come up with.
Not sure if it will be of any value as there are a lot of regions and all pictures missing now 😞
The file takes quite long too load.
I attach the pictures I could grab from your damaged file in an archive called Pics.zip.
From what we can read here in the forum it happens quite often that Prime files get damaged - PTC should provide a fix for this severe problem.
