Problem with ODEsolve
  • April 17, 2017
  • 2 replies
  • 6375 views
Hello everyone!
I have a question, how can I solve a system of equation, which is consists of three equation (two of them are Differential and other one is not) using ODEsolve or there is some other way?
So I had a system of two differential equation and everything worked just fine, but then I need to add one more equation and this equation is not differential. So I don't know are the ODESOLVE able to solve this kind of systems or not. It keeps telling me, that I have too few initial conditions. File 9 is a file where only 2 equation are solved.
Thanks for your help
Hi Vladimir Novikov,
first of all you should do the following changes:
.) The whole sheet is unitlesse - otherwise I guess we would experience severe problems with odesolve in Mathcad 15 (thats better in Prime). So Vladimir decided to write the supposed units next to the values in a textbox or separate math region for documentation and reference purpose only. This has no effext on the calculations.
I guess Valery would define every unit as being :=1 and then attached them in the unit field.
.) the equations with the "j" also are for refernce purpose only and have no effect on the calculations.
At the moment I haven't digged far enough in the calculations to be able to provide a solution but I guess the problem is, as Vladimir already guessed, that one of the equations is not an ODE.
I would say that not all the units are written in text boxes, on the contrary, many are written as if they were variables. The first (° C) for sure.
Attach is an absolutely unsatisfactory solution by turning phik into a function in an extra solve block.
I had to limit tau1 because of a strange error if its too large and the phi solve block takes quite long to calculate for higher values of tau.
Maybe its a tolerance problem because of too hight or too low values - when I set TOL to a lower value liek 10^-9 the odesolveblock fails for lower values of tau1, too.
Hope somebody has a better idea to tackle with that system.
vnovikov1-VisitorAuthor
your solution doesn't seems to work fine for me(((
Yes, The solution sure is unsatisfactory. I guess that you had changed the value of the system variable TOL from the default 10^-3 to something smaller. Try TOL:=10^-3 at the top of your sheet.
You may also set tau1 to a value lower than the 250 which worked for me.
But as your original sheet demanded to solve up to tau1=2000 (or was it even 20000?) I guess this would not be a satisfactory option.
