6-Contributor
February 26, 2026
Programming construct with for & if-then loop
  • February 26, 2026
  • 2 replies
  • 110 views
Hi PTC Community,
I am not sure why this programming construct will not work: apply the Nu function on a scalar & a column vector.
I use Mathcad Prime 11.0.1.0.
thodij
Best answer by Werner_E
And why is you function using the vector Re? It seems to be useless.
And why isn't it using its argument x??
So you are just looking for something like this?
You may also use
Which results do you expect in case of argument 99 and argument Re.l ?
Your function does not use its argument x at all. So the result would be the same for whatever argument you provide.
The error stems from the fact that you can't compare a vector with a scalar (Re<50).
But I don't see what the goal of your function should be.
thodij6-ContributorAuthor
6-Contributor
February 26, 2026
I see that Nu(99) is not covered in the logic ranges! Need to add another else if 50 <= Re < 100 in the logic.
For Rel = [49 200 230 300], I would expect Nu(Rel) = [0.25 0.50 0.50 0.75]
thodij
Werner_E25-Diamond IAnswer
You may also use
@thodij try this
@Werner_E covered most of this already.
I guess I only added the updated program that handles both single item and arrays automatically, without vectorization
6-Contributor
March 4, 2026
SPaulis -
I appreciate your taking the time to offer this additional/ more general solution.
Awesome PTC community!
thodij
