Programming using tables
BPP
8-Gravel
8-Gravel
Greetings to all.
I have a table (Table 1) with a large number of components (A1, A2, etc.) which in turn contains another large number of elements (E1, E2, E3, etc.), whose values ​​necessary to perform operations are in another table (Table 2).
Based on the table1, I need to get the values ​​of the elements forming part of each component (eg A1 (E1, E3), A2 (E2), etc) to perform subsequent operations.
To better understand what I want, I attached an example of what I have to do, and I want to automate as I do it manually would take me a long time because as I said earlier Table 1 has a large number of components
in advance thanks for the help
StuartBruff
(To:BPP)
Bryan Pérez Pérez wrote:
Greetings to all.
Do you mean something like the attached? I haven't tested it properly, but it might act as a starting point.
Stuart
6 REPLIES 6
MikeArmstrong
(To:BPP)
Hi Bryan, yes I believe it will be possible, but I am not entirely sure what you how you want it automated.
Where is the selection of the component?
StuartBruff
(To:BPP)
Greetings to all.
Stuart
Nicely done Stuart.
BPP
8-Gravel
8-Gravel
(To:BPP)
It's perfect, I made small modifications to work with the data table that I require and works great.
Thank you very much Stuart
Bryan
MikeArmstrong
(To:BPP)
You could simply this problem considerby by removing the strings.
StuartBruff
(To:BPP)
No worries, Bryan.
Stuart
