Roark's Table 24, 1a - Circular plate of Constant Thickness
- May 28, 2014
- 3 replies
- 5438 views
I am having difficulties with case 1a - 1d in table 24. Things start to fall apart when I enter dimensions for a circular plate that has radii smaller than 1 inch. The deflection at the inner and outer radius can't be calculated.
Am I doing something wrong? Is this a limitation based on the assumptions? i have attached screenshots for your reference.
