Runge-Kutta metod 4-th Order Approximation
YuK
Hi All.
http://en.wikipedia.org/wiki/Runge-Kutta
We know Runge-Kutta metod 4-th Order Approximation has 4-th Order Approximation. How to view this by Mathkad?
Thanks.
YuK
ValeryOchkov
(To:YuK)
AlvaroDíaz
(To:YuK)
Is 4th global, but that's only because is 5th local. You can see that with the 'symbolic not found' for a serie of order 5 in your setup.
To evaluate the local error, you starting acotating the value e = |yn+1-yn|. To do that, assume at first that yn have not error! (which is absolutely false).
Regards. Alvaro.
ptc-1368288
(To:YuK)
>Hi All.
>unge-Kutta
>Thanks.
>YuK
_____________________________
Not sure what you are looking for, YuK
Here is also Fehlberg 45.
jmG
