Best answer by Werner_E
Here is a utility function. The input is a vector of scalar values of any length. The return value is that vector element which occurs least often. If there are several, the first one to appear is chosen.
And here is a function working just for your special case of a three element vector with one single value
ttokoro
t.t.
18-Opal
October 13, 2022
Hi
Can this be done within a tolerance band?
If I had
I'd like to select 15 000
Here is a modified selectMin3 (yes, well, the name was chosen misleading, you should change it).
Werner_E25-Diamond IAnswer
