18-Opal
April 28, 2022
SKIPPING PARTICULAR LOOPS in Programming
  • April 28, 2022
  • 2 replies
  • 5207 views
Hi
How do I select which particular loops to skip. Depending on a condition I may want to skip loop "k" or "j" or "k" AND "j" and just get the next "i"
How do I go about doing that in similar scenario to below:
Best answer by Werner_E
Can you explain what the reasoning behind your mod condition is?
If the only goal is to eliminate the rows which contain at least one character of "Reject", this function might do the job:
The function is not ORIGIN-aware, so ORIGIN=0 is assumed.
The "break" isn't mandatory. If you delete it, the function is just working a little bit more inefficient because every time ALL characters in "Reject" are tested even after a character was already found in the string.
Yo can use not the for but the while loop.
How about putting a "break" command in the else branch and also an "if Flag=1  break" after the k-loop to also skip the j-loop ?
18-Opal
April 28, 2022
I think the break function will work for me but I will need to do the following in the programming
Run a for loop
Read a file (Has rows of data)
Carry out Operations (This results in some rows of data removed)
I want to use the “new” data file to be read read again  ( I dont know how to create the file and then get it to read it as a new file for the next iteration)
Keep doing till loop finished and data weeded out.
I think it may be an append or just a new writetext function function ?
Thanks for your help.
18-Opal
April 29, 2022
The index i is is from 0 to how many rows are in the file. So it will change as data is removed. Temp does not need index
