Sici spiral, create graphic
  • December 27, 2022
  • 3809 views
Between Christmas and New Year's I want to "play" with curves on graphs in Mathcad 14. I am particularly interested in the graphical representation of the Sici spiral (or named after Nielsen). It is represented parameterized in the Cartesian x-y coordinate system by x=Si(t) and y=Ci(t) with t>0. The Si and Ci functions are found in Mathcad on the f(x) menu. But they don't work in the diagram, even though I followed the instructions from the "Help". That's why I didn't attach a test file here. What am I doing wrong?
Kind regards, Alfred Flasshaar
Best answer by Werner_E
Of course you can redefine the function and evaluate the necessary integrals numerically that way:
As the help states, Si() and Ci() are symbolic only functions. They cannot be evaluated numerically and plotting requires numeric evaluation.
Werner_E25-Diamond IAnswer
In MathCad 14, can the drawing of the spiral be represented as the movement of a "drawing" symbol/dot in slow motion?
