20-Turquoise
September 26, 2022
Solve Iterative Equation on Natural Numbers ?
  • September 26, 2022
  • 2 replies
  • 2864 views
Hi, Everyone.
From the following:
How to Solve the Iterative Equation on Natural Numbers ?
Thanks in advance for your time and help.
Best Regards.
Loi.
Best answer by Werner_E
While cleaning up I noticed that I forgot to post the solution using Euklids algorithm. So before the file is deleted, I post it here.
Here we have no problem with numbers too high, as it seems.
Your definition seems not define series of numbers.
Its NOT defined what the NEXT pair (a1; b1) would be.
Is it (165; 238) or should it be (877; 1265) or would you rather like it to be (1589; 2292) ?
The general solution is a.1=165+k*712 and b.1=238+k*1027 with k being any integer.
If you settle for the smallest positive numbers, a first hack could be
Not much error checking or whatsoever and the 'math' method used is not Euklid or congruences but simple pure brute force 😉
lvl10720-TurquoiseAuthor
20-Turquoise
September 27, 2022
  With big numbers then:
(Attach ***.xmcd please)
Best Regards.
Loi.
Interesting error message. No idea what it should mean and why it pops up.
Solution: Don't use too high numbers 🙂
Werner_E25-Diamond IAnswer
