Solving Equations for undefined variable with units
- January 22, 2014
- 3 replies
- 13716 views
So, I am confused on how to solve an equation for an unknown with units. I am not sure if I am having unit problems or if my way of stating variables is incorrect. I am simply just trying to solve for the variable "d" which should have units in length. How should I declare variables that rely on other known and unknown variables? When should I solve an equation symbolically and just numerically in terms of getting proper units? I am used to using maple 16 so switching to MathCAD has been fairly intiutive but I am failing to pick up on certain features. If you fix my MathCAD code, I should be able to figure it out from the fix solution. Thanks!
