Solving equation with conditional statements
  • July 11, 2023
  • 3031 views
Hello All,
I am trying to solve an equation that has condition statements and find the roots.
Please help,
Best answer by Werner_E
So you should solve the equation for q0 and not for B.f. You can make the solution a function of B_f as explained in my previous answer.
You may use either a solve block or the root function - its up to you.
You can speedup the calculation significantly (factor 5) by using the approach which I already showed in a previous posting
  • The symbolics can't do well with conditional expressions, so you should rather use Primes numeric methods (either a solve block with "find" or the "root" command.
  • I guess you rather want to solve for B.f and not for the function Deltaq(B.f)
  • Again you used function names as if it were simple variables! If you use a function, you have to provide the function argument!
You could also do it that way:
or maybe even that way
fahmed-214-AlexandriteAuthor
What if I have two variables to solve!!
Your solve block with just one equation but two variables to solve for does not, make much sense!
You may notice that the solve block returns V totally unchanged and only calculates B.f based on the one and only equation you provide.
If your goal is to get the value of B.f for various values of V, then you should change the solve block to only look for B.f and turn it into a function by writing sol(V):=Find(B.f)
Then Sol(2000 kN)= gives you the B.f value for this value of V.
And you may define a vector Vvec of V-valuse and writing sol(Vvec)= gives you the vector of corresponding B-f values. You should vectorize that function call.
