Solving equation with conditional statements
  • July 11, 2023
  • 3031 views
Hello All,
I am trying to solve an equation that has condition statements and find the roots.
Please help,
Best answer by Werner_E
So you should solve the equation for q0 and not for B.f. You can make the solution a function of B_f as explained in my previous answer.
You may use either a solve block or the root function - its up to you.
You can speedup the calculation significantly (factor 5) by using the approach which I already showed in a previous posting
  • The symbolics can't do well with conditional expressions, so you should rather use Primes numeric methods (either a solve block with "find" or the "root" command.
  • I guess you rather want to solve for B.f and not for the function Deltaq(B.f)
  • Again you used function names as if it were simple variables! If you use a function, you have to provide the function argument!
You could also do it that way:
or maybe even that way
fahmed-214-AlexandriteAuthor
What if I have two variables to solve!!
Werner_E25-Diamond IAnswer
