Solving two simple ordinary differential equations with odesolve. Why the second one fails?
  • June 9, 2017
  • 2 replies
  • 3451 views
Hi all!
Maybe I'm losing in a glass of water, but I can not solve the second differential equation with odesolve, in the problem hereunder exposed. What's wrong?
Best answer by ViktorKorobov
Dear F.M.,
Choose the method for solving the ODE by right-clicking on Odesolve: Adaptive instead AdamsBDF.
Viktor
Hi F.M.
I'm missing the equation Fy(x) in the solver.
(or is it F0y(x)?) if yes, i got this solution:
is this right?
Best Regards, Volker
-MFra-21-Topaz IIAuthor
Thanks Volker,
This is a basic case and I need to check out the results.
In the general case, the analytical solution of the first equation is not known. It is used in the second where the problem arises.
Greetings
Frank
Hi Frank,
And the answer is sooooooo easy with the choice of Adaptive mode.
You can keep your sheet like it was in the origin and change only to adaptive and it works perfectly.
Viktor is absolutely right.
Man lernt nie aus....
Greetings, Volker
Dear F.M.,
Viktor
Hi Viktor,
thank you very much.
Greetings
Frank
Frank, I was glad to help. But I do not know why Adams/BDF-method not work here.
Viktor
