Tags and Internal Links to Tags
  • April 21, 2023
  • 2577 views
Can someone upload a worksheet sample on how to use Tags and internal Links
Cheers
Terry
Best answer by rgunwaldsen
Here's a simple worksheet put together to help my granddaughter's middle school math.
So is it really the intended normal behaviour that when you jump to a tagged region, that region ends up at the bottom of the screen and not at the top?  I  would consider this being quite strange and unintuitive (OK, having to use Ctrl-left click isn't intuitive either, I guess)!
The region not having the focus isn't that bad IMHO, but the worksheet should at least be scrolled so that the region is a the top and not at the bottom. This would make much more sense, the sheet of @rgunwaldsen  is a good example to show how bad the current behaviour is. Furthermore a simple left click or double click would be much preferable over the ctrl-click which is currently needed to trigger the jump.And of course a cursor change when you mouse-over a link so you clearly see thats it a link.
Somehow the whole thing looks quite half-baked and unfinished to me. But then - that way it fits perfectly to the rest of Prime with its missing features (compared to real Mathcad), its half-baked chart component or the list boxes with their unit problems and missing scripting.
