The function values for the end points of the interval must be of opposite signs.
Leakchhayvat
8-Gravel
Dear Expert MathCAD Prime Users,
While I am doing my assignment of Reinforcement Concrete Column Design I have a problem when I reached design axial compressive  I can not find the Value of a as you can see in my attached file in MathCAD Prime 7.0. The error message is "The function for the end points of the interval must be at opposite signs".  As I mentioned problem, I would like you to show me how to fix  this issue in order I can make a Column Interaction Diagram.
I am looking forward for your help and recommend.
Thank you!
May be you should check the unit and sign of Stress in Reinforcement Bar at first.
May be this one.
May be this one.
I have tried it. Anyway, would you mind please kindly send me the that you edited to me? I will have a look. Because I know that I still miss something in this, but I can not find it.
Just change the * to , at min function.
Thank you sir! My bad.
I have solved it.
