Unit conversion in mathcad
Hi, I'm facing an issue while converting the unit in Mathcad. Here I attached the issue.
This was the resulting value of the corresponding equation. But I need the value in N/mm^2.
If I change the unit, it does not result properly.
The resultant value should be in N/mm^2.
Can anyone suggest the better way to solve this issue?
