Unknown error of script with excel hyperlink semicolon
  • July 4, 2018
  • 1618 views
Hi, I met the strange issue with scriptable component.
I try to write a table with a hyperlink to excel file. Everything is OK without hyperlink note "link"
If I add semicolon+"link", I get an unknown script error. Problem is in a semicolon.
File is attached
I changed my regional settings as described in this article
https://lockone.wordpress.com/2015/08/06/excel-now-using-semicolons-instead-of-commas-in-separating-formulas-fix-it-now/
now, with comma everything is OK
Don't have an explanation or solution.
But if you put the lines
Set Cell = ws.Cells(2,1)
Cell.Value = "=hyperlink("C:\Temp.xlsx";"link")"
in your code (and omit the nested loops which throws the error) you get a more meaningful (??) error - at least its not the unknown error.
