Using results from Solve command
- March 17, 2010
- 1 reply
- 3118 views
I am running MathCAD 14 on WinXP. I have an equation with one variable in it, b. See my attachment. I type the equation and then use the Solve keyword to display the solution for b. Since b is a cubic in the equation, it returns three results. Here is my question...I can't figure out how to use b vector results in subsequent operations. Typically, when I want to use a variable in subsequent operations, I will first define the variable with the colon key and the variable is then defined and usable. After using to Solve keyword to display b, I don't know what to do to use b later in other operations. Any input? Thanks, M Ridzon
