Best answer by Werner_E
You have used a wrong syntax!
The syntax for OdeSolve is different in Prime and real Mathcad.
Correct is: alpha := Odesolve (t, t.end)
Replace alpha by t and I guess it will work OK.
EDIT: Just see your follow up. In MC11 you can see the correct syntax!
No problem in Mathcad 11 too
Werner_E25-Diamond IAnswer
Thanks, Werner!
Ich hab fergessen!
Prime can work here with units but does not have an animations!
Нет в жизеи счастья!
