a loop creating a matrix with 2 columns
  • July 15, 2016
  • 2 replies
  • 12598 views
I am trying to write a simple command to create a matrix with two columns one of which would display a value of the governing shear force and the other with text (as in the screen below). When I loop it, the result is not what I intended. I would be grateful if someone could indicate what is wrong.
MK
Best answer by Werner_E
Here are examples of what I was talking about:
1)
2)
Werner
Please don't post just pictures, better to attach your worksheet.
BTW, you are not doing anything wrong, its Mathcad not passing the whole range as argument, but when a function is called with a range as argument and is not assigned a variable, an implicit loop is executed and the function is called separately for every value (similar, but not the same as vectorized function calls).
Ranges are a beasty thing and should be used just for a few couple of things. Passing a range as function argument is not one of them. You will experience also other strange effects. Just try to assign the outcome of your function to a variable 😉
You see, that way you get what you are asking for. Nevertheless I would rather create x as a vector, not a range.
Or you might consider adding additional arguments to your function - start value, second value (or step size - up to you), end value.
WE
Werner_E25-Diamond IAnswer
1)
2)
Werner
mkraczla1-VisitorAuthor
Now I am trying to get rid of a range of x combining a for loop with a while loop but not succeeding. Instead of a value V for each x calculated within the while loop, I receive only one value which on top of that is incorrect. Could you please give me an example of how to use a combination of a for loop with a while loop. If possible on the example I attached in the post above.
MK
As Werner notes, the problem is that x is a range variable, not a vector. A range variable is an iterator, so Answer(x) is called for each value of x, not once for all values of x. So it's called for x=0.25m, which yields a one row two column matrix, then it's called for x=0.3m, which yields a one row two column matrix, etc. Make x a vector and you should get the expected results.
The crazy thing is, that assigning the function call to a variable gets exactly the demanded matrix. I would have thought that Mathcad would throw an error.
I would expect a nested matrix.
