a loop creating a matrix with 2 columns
  • July 15, 2016
  • 2 replies
  • 12598 views
I am trying to write a simple command to create a matrix with two columns one of which would display a value of the governing shear force and the other with text (as in the screen below). When I loop it, the result is not what I intended. I would be grateful if someone could indicate what is wrong.
MK
Best answer by Werner_E
Here are examples of what I was talking about:
1)
2)
Werner
Please don't post just pictures, better to attach your worksheet.
BTW, you are not doing anything wrong, its Mathcad not passing the whole range as argument, but when a function is called with a range as argument and is not assigned a variable, an implicit loop is executed and the function is called separately for every value (similar, but not the same as vectorized function calls).
Ranges are a beasty thing and should be used just for a few couple of things. Passing a range as function argument is not one of them. You will experience also other strange effects. Just try to assign the outcome of your function to a variable 😉
You see, that way you get what you are asking for. Nevertheless I would rather create x as a vector, not a range.
Or you might consider adding additional arguments to your function - start value, second value (or step size - up to you), end value.
WE
Werner_E25-Diamond IAnswer
1)
2)
Werner
mkraczla1-VisitorAuthor
thank you all,
I would like to ask one more question, perhaps related to this thread. I have a while loop and even though the outcome is correct, there is this little thing that has been bugging me; namely I can extract only results for one variable (please see the capture + the file). V.s in the case of the capture.  I would like to know if there is by any chance a way to extract several indicated variables; in a form of a matrix for example, thus V.c, V.s and V.R and so on.
MK
As Werner notes, the problem is that x is a range variable, not a vector. A range variable is an iterator, so Answer(x) is called for each value of x, not once for all values of x. So it's called for x=0.25m, which yields a one row two column matrix, then it's called for x=0.3m, which yields a one row two column matrix, etc. Make x a vector and you should get the expected results.
The crazy thing is, that assigning the function call to a variable gets exactly the demanded matrix. I would have thought that Mathcad would throw an error.
I just looked back at an old worksheet where I compared the numeric and symbolic behavior of several variations of this function for versions 11, 12, 13, and 14. Apparently none of the variations worked in version 11 for V:=function(x), where x is a range variable, even though they all work for V:=function(range value).
