circuit Modeling for Electromagnetic Compatibility
  • December 13, 2016
  • 5 replies
  • 4481 views
CHello everybody  Which of you can help me for this program! The progame is a book (circuit Modeling for Electromagnetic Compatibility) .. EMC Series Ian B. Darney.
thank you so much
Best answer by Fred_Kohlhepp
I see.  You don't want to learn.  You don't want to waste your time; you want me to waste mine.
Make your Prime 3.1 sheet look like this:
The document describes a few mathcad programs. What's your problem exactly?
You might want to look here: Transient Emission Model
bdjel1-VisitorAuthor
thank you
Which is the difference between the old version and premium 3.1.
Because some programs do not execute correctly.
greetings
A Word document that shows two images of the same Mathcad worksheet. What do you want us to do with it?
23-Emerald I
December 14, 2016
The document shows clearly a Mathcad 15 sheet.  Fire it up and start editing!  I doubt if anybody here will do it for you.
Thank you very much for your remark, but I want to understand by someone Experimented of mathcad for just saving time.
The problem that this program does not run on premium 3.1.and also I am a mathcad beginner.
This is the problem.
    greetings
That program will work in Prime 3.1. If it doesn't, post your worksheet.
I can only suggest something else. If you like.
thank you for all
While I agree with Fred's comment, back in 2007, the task to me seemed more formidable. Thanks to the collab (T. Gutman) for the attached worksheet that I use, modified somewhat adding units, converted to Prime (which wasn't easy).
I hope this helps, but I'd definitely try transcribing the word info onto a MathCad worksheet.
thank you very much
