is it possible that explicit shows only numbers and short numbers like 2-3 digits
You may consider using "explicit" in conjunction with "float,3" or the like but you have to be aware of the fact that this also affects the precision of the whole calculation.
Attach please the sheet or its short variant.
Sometimes it helps if you work with ONLY exact numbers. That means prevent using reals, use integers instead, change your 0.12 to 12/100, 1.8 to 18/10 etcetera.
I do like this - and no problems:
and my other question, that is it possible that explicit shows only numbers not units ?
explicit is a symbolic command. Symbolics doesn't understand units, they get treated as variables
