need help with piecewise function
  • January 15, 2016
  • 5 replies
  • 5298 views
hey could someone help me with this ? i need to putt this function into mathcad prime 3.1 and i have no idea how to do it. help
See please the attach too
Use if...else in programming, as Valery shows. You can simplify the expression you show. In the first line t must be less than 123, in which case it can not be greater than 124. So you have three cases:
t < 123
123 < t < 124
t >= 124
Note that you are missing the case for t=123.
amedy?ski1-VisitorAuthor
hey, i need to write a function like this, i dont know how to write 3 variables of t. can someone help me.pomocy.png
You need a return statement to make the program return a value and then exit:
Or you could assign the values to a variable, and put the variable on the last line:
thank you very much.
i have another question. what if i would like to do plot with FTOT(t) and t (from 1 to 1000) ?
Create a range variable from 1 to 1000, put the range variable on the x-axis, and FTOT(range variable) on the y-axis.
I suggest you go through the tutorials. It wouldn't take long, and it would answer most of these basic questions for you.
i figured it out but thanks. but i need help with differential equation. so far i have something like this(mathcad file) a have to do something like this(screenshoot). i wolud appreciate any help. i also made a post i physics section.
