I am calculating mean wind speed at variable heights (ze) as as shown in above function.
Now I want to create a table with variable heights say 10m, 15m. 20m and tabulate the corresponding wind velocity, so that i can reference it any where in the calculation and I also want to know how to extract exact data from table with the variable say like lookup functions in the excel.
You apparently want to use Prime...
You have a function that models a relation between height an wind speed.
In that case you don't need to tabulate, unless for presentation purposes...maybe.
To find a wind speed, just call your function with the appropriate height.
