while loop conditional test problem
ptc-4449700
Hi, I am having a problem getting a while loop conditional test to behave as I expect. See the attached example.
Any ideas what I'm doing wrong?
Thanks, Pete.
Looks like you are getting rounding errors.
if i =x then it will increment to 0.1 greater , in the case of x=2 if i=2.0000000000000001 then it will return that value.
changing the condition to |i-x| > 10^-5 or similar should help
Andy
Andy
Hi Andy, I'd initially thought the same but couldn't understand why it was failing (function_error returning non-zero) on the first loop. But (typically) it was user error. My function last line should return i-1 not i, so that means the function_error return is zero on the first loop, only becoming unpredictable after a number of loops... thus numerical errors it is. Thanks
Pete.
(To:ptc-4449700)
Thanks, Pete.
You should expect function_error to always return 0.1, because you have used <= instead of <. So when i==x an additional 1/10 is added to i and you function should always return x+0.1.
And even this is not really true - only for values of x which are multiples of 0.1.
Concerning the rest and main part of your question the answer is: roundoff errors by numeric evaluations. You get the correct results by evaluating symbolical. When evaluating numerically set the number of decimal places to the highest possible numer (17) and have a look. Best guess is that numerical evaluation use the "normal" way to deal with numers and that is converting them to binary. 0.1 in binary has an infinite number of decimal point an has to be truncated.
By adding 0.1 ten times mathcad got a value slightly under 1 and therefore added an additional 0.1.
by adding 0.1 20 times it got a value slightly over 2 and the while loop stopped (correctly).
You can try working with integers as much as possible
But even then you get slight rounding errors if x is not integer.
As long as evaluations are done numerically you will run in such situations. You might try not to ask if a==b but if abs(a-b)<eps where eps is a small value like 10^-6. Or in your case you might ask for i<=x+eps.
WE
Hi Werner,
thanks for your reply. In my problem the steps will be uniform, so I only need to consider values that are multiples of that step. I like your suggestion to use integers to avoid the numerical error, I think I will do that.
Thanks, Pete.
