As Henry already stated your solve block is missing the beginnng "Given", you had a typo (LW instead of Lw) and most of all you mixed up literal (.) and vectorial ([) subscript quite a lot.
See attached
@henry: The vectot V is not a problem as the solve block is turned into a function of V and so its the parameter which is fed into the first two equations and not the vector.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
