Best answer by -MFra-
I did the conversions. But there are some errors (divide by zero)
-MFra-21-Topaz IIAnswer
The division by zero also occurs in the original Mathcad sheet (the "flexible" one).
The reason is that at the top the number of conductors (n) is set to 1 and the distance a.s of the conductors is set to 0.
The division by zero occurs in the section "Effects of bundled Conductors". So while it may not be nicely done, I guess its expected behaviour  if the calculation assumes just one conductor.
Yihai_Li1-VisitorAuthor
Thanks very much for the explanation. Will definitely look into the issue again. Cheers.
