I want to personalize the "GetIdentityInfo" service in PTC.SCA.SCO.AssetMonitor.AssetList.AssetListServiceController to show different properties for the assets in the asset list.
I can override the default service and write my code, but I would like to have the code for the default service so that I can personalize it instead of writing the code from scratch. Is there any way to get the default code for the services??
Thanks in advance.
Finally, I was able to do it by modifying the "GetAssetAtributes" service inside PTC.SCA.SCO.AssetMonitor.AssetList.AssetListServiceController thing following the MFA documentation.
Thank you.
Hi @Iker ,
There is no way to access the service code.
You can only customize the things upto a limited extent and that is available in customization guide of manufacturing apps.
Himanshu
Thank you.
