Add route to operator advisor connector
  • October 14, 2020
  • 2 replies
  • 1843 views
Any information how to add a route to the MPMLink OData Connector in Operator Advisor by code? Found the
AddRouteDefinition but I don't understand how to use it. There is no GetRouteDefinition so I can't copy from there. Let's say I want to create a simple route for GetParts with the name: "GetParts" and Endpoint: "getParts".
Best answer by slangley
Hi @fredrik.tell.
The fix for this issue was delivered in ThingWorx 9.2.x.  Please check it out and if satisfied, please mark the appropriate response as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
Hi @fredrik.tell
There is a case opened with PTC Technical support for assistance on this query and concerned Engineer is working on it.
We will post the solution here as well once the case is resolved.
Himanshu
slangleyCommunity ManagerAnswer
Community Manager
August 11, 2021
Hi @fredrik.tell.
Regards.
--Sharon
