I installed both Thinngworx foundation server and Industrial Connectivity, version 8.3 trial. The Thingworx foundation server is working well, I can connect to composer in Browser. However, I tried to configure IC to connect to Thingworx, and then get an error:
Date Time Level Source Event
1/8/2019 10:50:18 AM Error ThingWorx Native Interface Connection to ThingWorx failed. | Platform = localhost:80/Thingworx/WS, error = could not initialize a secure socket connection.
Thanks a lot!
Hi @RV_7 ,
Can you set Disable Encryption to yes and try to connect.
If this does not work, additionally change localhost to 127.0.0.1 in the host property.
Himanshu
Hi @grantji,
Can you please validate your ThingWorx tomcat server port (80 in your case) is correct, the app key is valid. Also enable Trust all certificates and Trust self-sign certificates and reinitialize the KepServerEX
Himanshu
Hi @grantji,
You need to right click on KepServerEx icon on bottom right of your machine, you will get reinitialize option there.
Himanshu
Hi @grantji,
Can you please share the ThingWorx application logs and event logs of KepServerEX.
Himanshu
Hi Himanshu,
sorry for this late reply, I took a long leave for some urgent things. Today I try again, and still cannot connect to the web server. I attached some log files here, fyi. Thanks a lot.
Grant
Hey @grantji
the security.log show a http validation error. I found some TechSupport articles to this issue but i am not sure if the causes your connection issue. Could you please send the Application.log file that is in the same folder like the two over log files.
Seb
Thanks @grantji
but the log is full with ThingWatcher Messages.
Could you send me the archive folder that is in the log folder to see older log files.
Seb
Hi Seb, I got the log files under C:\Program Files (x86)\twxFoundationH2Trial-8.3.2\tomcat\apache-tomcat-8.5.23\ThingworxStorage, pls see the attachment. If need, I can send the teamviewer connection to you. Thanks in advance!
It looks like you have not used the free trail installer for the setup
I dont see any connecting try in the logs.
I would like to take a look an the system, i send you a pm.
Seb
Thanks Seb. I also think the Industrial connectivity didn't try to connect to the Tomcat server, not sure if there is any environmental configuration problem. Because the timezone is difference for us, I will email you next Monday, have a good weekend!
Grant
Hey @grantji ,
i could find the problem. I changed the connection information in KepServerEx from localhost to 127.0.0.1. for some reason localhost is blocked on the server. i assume its a security setting.
I haven not looked deeper into it.
The connection to Thingworx should work now.
Seb
Hi Seb,
It works now. This problem really perplexed me for a long time. Thank you very much for your big help.
I remember that I ever enable "127.0.0.1 localhost" in C:\Windows\System32\drivers\etc\hosts, and I can access "http://localhost/Thingworx/" in Internet Explorer, I am wonder why the localhost doens't work for Industrial Connectivity. Is there any security setting in Industrial Connectivity? Thanks again and have a good day!
I am not aware of any security setting in Industrial Connectivity that could be responsible for that.
Maybe its the Windows firewall or any setting on the host.
Seb
I also guess the problem related to Kepserver settings. I have changed the hosts file (enable the line "127.0.0.1 localhost" ) and switched the Windows Firewall off. Thanks!
We just tested it on Win 10 without issue but i faced the issue with Win server.
Thanks to all for your replies!
We will try to find the reason for this behavior and get back to you.
Seb
Hi Seb, I downloaded latest trial version on the official website. Just I checked the version of "Thingworx Industrial Connectivity", it is 8.3.65. My OS is Windows Server 2012, installed on Virtual Machine.
Grant
Hi Seb,
I would like to know if there is any progress from testing team? Thanks a lot in advance!
Grant
I got the feedback from RnD that the issue could not be reproduced.
Do you have the change to test it with the newest KepServerEx version?
Seb
