I have configured DPM equipment. using https://www.ptc.com/en/support/article/CS371476 this link
But I cannot select the WorkCentre showing some error. Kindly check attached image.
I have also checked
Please guide
Do you have the DPM Permissions module installed? If so, there is a final step that must be done after importing your assets. The Enterprise Network in composer must have a certain visibility permission added. The network will have the name of the enterprise you loaded and it needs to have visibility permissions for PTCDTS.Base.Permissions.Default_OR added.
If you don't have that module installed, could you provide Script Logs?
Thanks For the replay...
I have not installed DPM Permissions module. How to install it ? Can you have any document?
If yes please share with me. I will install it.
Also Please check attached Script Log, Error log and application log for your reference.
You don't need to have it installed. If it was installed, that may have been the cause of the issue.
This may have been caused by something going wrong with the setup. Generally, we don't do manual setup of the Equipment List. While not officially supported, we recommend using the DPM Data Import Extension found here.
This allows you to add all the info to a spreadsheet and import that spreadsheet. I'd recommend refreshing your image back to a blank DPM environment.
I have checked this link but it has available only 2 files one is license and other is read me.
Can I get this file
If you click on releases on the middle right of the page, you'll be directed to all the versions. Make sure you grab the one specific to your version of DPM.
Ok .Thank You
Hello @KG_96,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
