DPM Production Dashboard
  • July 17, 2024
  • 2783 views
I have configured DPM equipment. using  https://www.ptc.com/en/support/article/CS371476   this link
But I cannot select the WorkCentre showing some error. Kindly check attached  image.
I have also checked
https://support.ptc.com/help/digital_performance_management/r9.5/en/index.html#page/dpm/digital_performance_management/production_dashboard/production_blocks.html#
Please guide
Do you have the DPM Permissions module installed? If so, there is a final step that must be done after importing your assets. The Enterprise Network in composer must have a certain visibility permission added. The network will have the name of the enterprise you loaded and it needs to have visibility permissions for PTCDTS.Base.Permissions.Default_OR added.
If you don't have that module installed, could you provide Script Logs?
KG_9610-MarbleAuthor
Thanks For the replay...
     I have not installed DPM Permissions module. How to install it ? Can you have any document?
If yes please share with me. I will install it.
Also Please check attached Script Log, Error log and application log for your reference.
6-Contributor
July 24, 2024
I have checked this link but it has available only 2 files one is license and other is read me.
Can I get this file
