6-Contributor
September 4, 2024
DPM Uninstall
  • September 4, 2024
  • 3 replies
  • 1178 views
How I can Uninstall DPM from Thingworx server.
Best answer by AdamR
There is not an official uninstall process for DPM.  The only way to remove all of the functions would be to removed each extension individually.  However due to dependancies of the extensions this is difficult to do.  After this you would also need to delete/remove the SQL table or schema that was setup for DPM.
You would need to delete most of the PTCDTS labeled extensions then the Impl extensions.  You will still run into dependancies but the removal will tell you which one exist and you can follow each to removed the related extensions.
Catalina
Community Moderator
September 4, 2024
Hi @KG_10929768
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster, as well as articles on our Knowledge Base.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Moderator
You could try removing the extension on the installed extensions page, it maybe have been divided or brought over dependencies on installation. Don't know if that can give you problems or if it will modify any DB.
AdamR14-AlexandriteAnswer
