Demo dataset for Manufacturing Apps 9.x
  • August 24, 2021
  • 2549 views
Hi there,
I've been searching around for the updated DemoSimulatorPackage (kepware simulator + twx entities + twx data) but I'm afraid I found broken links or outdated stuff.
Could you point out where the DemoSimulatorPackage or similar for manufacturing apps 9.x is located at?
PD: here Sharon mentioned it was going to be released on June 2020.
Nahuel
Best answer by ptcwbowman
Hello @nahuel,
  What are you looking to do?    8.4 is the latest version of the demo system.  KPIs changed between 8.4 and 9.0 (we changed the way the KPIs are calcualted) but if followed the upgrade processes it should update them.
  The 9.1 upgrade is optmized for size, and it changed the "remote" thing bindings (to get rid of double processing data).
   Perhaps if you tell me what you are trying to do, I can help you find what you are looking for.
Regards
Ward
Community Manager
August 25, 2021
Hi @nahuel
Did you try this one?
--Sharon
nahuel14-AlexandriteAuthor
Hi @slangley ,
Yes, I tried that one out. Looking at the .xml files it can be seen that it has been exported from TWX 7.3. So it's kinda old.
The most up to date package that I found (from TWX 8.4) is this one (it is located under the "Load Factory Simulator into ThingWorx Kepware Server" section).
I currently upgraded the last one to TWX 9.1 lossing the KPIs functionality in the process.
So if you do find one up to date package, please let me know.
Nahuel
Hello @nahuel,
Regards
Ward
