Hi there,
I've been searching around for the updated DemoSimulatorPackage (kepware simulator + twx entities + twx data) but I'm afraid I found broken links or outdated stuff.
Could you point out where the DemoSimulatorPackage or similar for manufacturing apps 9.x is located at?
PD: here Sharon mentioned it was going to be released on June 2020.
Nahuel
Hello @nahuel,
What are you looking to do? 8.4 is the latest version of the demo system. KPIs changed between 8.4 and 9.0 (we changed the way the KPIs are calcualted) but if followed the upgrade processes it should update them.
The 9.1 upgrade is optmized for size, and it changed the "remote" thing bindings (to get rid of double processing data).
Perhaps if you tell me what you are trying to do, I can help you find what you are looking for.
Regards
Ward
Hi @slangley ,
Yes, I tried that one out. Looking at the .xml files it can be seen that it has been exported from TWX 7.3. So it's kinda old.
The most up to date package that I found (from TWX 8.4) is this one (it is located under the "Load Factory Simulator into ThingWorx Kepware Server" section).
I currently upgraded the last one to TWX 9.1 lossing the KPIs functionality in the process.
So if you do find one up to date package, please let me know.
Nahuel
Hello @nahuel,
Regards
Ward
Hi @ptcwbowman
Thanks for jumping in. I used the demo system (after upgrading it) as a starting point for developing a demo.
Although at this moment the development is done it would be helpful to have a more up to date demo system for future times.
I posted a question about a not so different topic, Kepware Real Use Case Demo (or closest).
Maybe you can help me there.
Nahuel
