Error "Could not load "PTC.Factory.KEPServerEX.ListServers". Reason: 403 - You don't have a valid license"
  • July 7, 2017
  • 4769 views
Hi there
I have imported the extension in my ThingWorx 8.0.1.
Configure Kepserver with the info presented, but when I try to access the app mashup I get the error:
Could not load "PTC.Factory.KEPServerEX.ListServers". Reason: 403 - You don't have a valid license. Ask your administrator for access to the following license feature: twx_mfg_common
However when I check my license I do have twx_mfg_common:
Could you tell me what can be wrong ?
Christophe
Best answer by stmarchessault
Hi Christophe,
Okay, yes I can see I overlooked that the license was already present.
Please confirm, did you import both extensions? (ThingworxManufacturingApps-8.0.0-00-extension-dependencies.zip and ThingworxManufacturingApps-8.0.0-00-extension.zip)
Have you closed the Composer window and restarted Tomcat?
Best regards,
Steven Marchessault
Technical Support Engineer | Kepware Technologies
Hi Christophe,
It is necessary to also obtain a new license file and manually place it in the root/Thingworx directory.  Please refer to the more detailed steps outlined in the 'Installing ThingWorx 8.0' guide:
https://support.ptc.com/WCMS/files/173731/en/ThingWorxManufacturingAppsSetup_8-0-1.pdf
"..3. If you have not already done so, create a folder called ThingworxPlatform at the root of the drive where Tomcat was installed. NOTE: Ensure the ThingWorx server has Read and Write access to the ThingworxPlatform and ThingworxStorage folders. Without these permissions, the server will fail to start.
4. Obtain the license.bin file from the PTC Support site:
a. Log into the PTC Support site.
b. Click Manage Licenses.
c. Click PTC ThingWorx>PTC Licensing Tool.
d. Click Download.
5. Rename the file to license.bin and place it in the ThingworxPlatform folder. NOTE: Failure to place the license.bin in the ThingworxPlatform folder will result in ThingWorx not starting after deployment."
6. After following these steps, be sure to close the Composer window and restart Tomcat.
Do you find you are still seeing the same error?
Best regards,
Steven Marchessault
cmorfin19-TanzaniteAuthor
Hi Steven
Thank you for your prompt answer.
I already have the license.bin under /ThingworxPlatform folder, this is what the output of service GetCurrentLicenseInfo is showing in my previous post.
but I still get the error
Christophe
Hi Christophe,
Best regards,
Steven Marchessault
