KPI & Shift analysis
  • February 10, 2021
  • 3062 views
I'm planning to customize the manufacturing app shift management (using ยง'Configuring KPI Calculation' of the documentation). I would create the schedules & shifts and overwrite the shift manager in order to consider the current day of the week. I'm still looking for the right service to overwrite for that, but my problem is another:
I cannot find a place where the KPIs are displayed per shift / with shift information or filter. Am I missing something?
Best answer by nsampat
@gch ,
Thank you for clarifying your desired design outcome.
Based on this, there is no out of the box functionality to achieve this and would require a custom dashboard.
You will need to create a service that pulls the UIDs based on a subscription for the days you want to associate with them. From there you can create a new dashboard to display the information.
Neel
Hello @gch ,
Thank you for posting your question to the PTC Community.
Can you verify what version of MFG Apps you are using, so that I may provide the proper response to your inquiry?
The PTC HelpCenter has a topic that may be of assistance to you for this goal, which can be found here:
Mfg Apps 9.1 https://support.ptc.com/help/thingworx/apps/r9.1/en/#page/thingworx_apps%2FCustomizing_the_Apps%2Fdefining_sites_shift_schedules_and_shifts.html
Mfg Apps 9.0
https://support.ptc.com/help/thingworx/apps/r9.0/en/#page/thingworx_apps%2FCustomizing_the_Apps%2Fdefining_sites_shift_schedules_and_shifts.html
Mfg Apps 8.5
https://support.ptc.com/help/thingworx_apps/r8.5/en/#page/thingworx_apps%2FThingWorxAppsCust%2Fconfiguring_kpi_calculation.html
Neel
gch13-AquamarineAuthor
we are using the manufacturing apps 9.1. I'm using the given link to develop the shift management. But I miss the KPI dashboard displaying shift information.
Hello @gch ,
Did you complete the step where you have to associate the equipment to the shift schedule?
https://support.ptc.com/help/thingworx/apps/r9.1/en/#page/thingworx_apps%2FCustomizing_the_Apps%2Fassociating_equipment_to_shift_schedules.html%23
The KPI dashboard requires to have a ShiftScheduleUID associated to the equipment in Properties and Alerts in composer.
Another item, make sure you save each change so that it will persist.
@hchanana , do you have any other recommendations for this user to check?
Neel
