6-Contributor
March 13, 2025
RTPPM data translations
  • March 13, 2025
  • 1016 views
Hello, I've been trying to find the data tokens for the quick time picker dropdown list in Downtime events dashboard in RTPPM but unable to do so. I need help in locating these tokens so I can add their translations in the respective localization tables. Thanks!
Best answer by mstarnaud
Hi MC
These time intervals don't use tokens. They're stored in an SQL table called QuicktimeInterval in the RTPPM database. There's a Name and Displayname column, you must not change the Name (it's the way the program recognizes it), but you can change the Displayname : it's how it appears in the screen. You will need to write SQL queries to read & update the Displaynames.
Sadly this does mean there is no language-dependent translation. All users will see the same words, no matter which language they use. We have request PSPT-76679 to change the Displayname name system into Tokens for these time intervals, but this change has not been started yet.
I also created this Article and it should get updated if/when the solution changes.
Let us know if that solves your issue.
mstarnaud16-PearlAnswer
Hi MC
6-Contributor
March 13, 2025
got it, thank you.
