Static Property to Bound
  • April 1, 2019
  • 1386 views
How can we convert static property to bound property?
Best answer by hchanana
Hi @Abhinav_Indana ,
You need to edit the static property from the composer, change type from "My Property" to "Local Bound" and add the Thing/Property Name in Property Bindings. Make sure to check the Persistent and Logged values as required
Capture
Himanshu
If the above response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
hchanana16-PearlAnswer
Capture
Himanshu
