ThingWorx Manufacturing Apps Trial Version "Status Of Week" Does not Work
  • August 14, 2017
  • 5 replies
  • 12081 views
Hello Everyone;
We are using ThingWorx Manufacturing App and so far we can successfully connect to KEPServerEX and fetch simulated data properly. Alarms also works fine. But in Asset Advisor -> Performance Tab, there is "Status Of Week" section which does not working at all. % and Hours sections both are not getting any data.
Any suggestion will help.
Thank You.
Best answer by sl-2
Hi Varathan,
It's allready working. I was using "," as decimal separator as you said. So I switched format of date and also "Language for non-Unicode programs" to English. Then I reinstalled Thingworx and KEPServerEX and it's working now.
Thank you for yesterday's Webex meeting and your help. I hope you fix error with comma soon,
Stanislav
Community Manager
August 14, 2017
Hi Murat.
Are you logged in as Administrator or a user you created?  If you try under Administrator, do you still get the same results?
--Sharon Langley-Anderson
mberber12-AmethystAuthor
Hi  Sharon Langley Anderson
I am logged on as Administrator.
Community Manager
August 15, 2017
Hi Murat.
Please check to see if the properties are defined with a Base Type of INTEGER.  If so, change them to Base Type of NUMBER.  If this does not resolve the issue, please provide the application log for analysis.
--Sharon
By looking at your screen shot, the status this week chart widget is not pulling the data. I see an error. I also see Running as 0 minute. Can you try this after few minutes allowing machine to do calculations?
Varathan
Hello Sharon and Varathan;
I am pulling data from KEPServerEX Simulated data. In KEPServerEX property there is no integer section so i give a Float value which works fine with other wigdets. Alarms also works fine too. I can make planned or unplanned stop by giving boolean datas manually from kepserverex. But status of week just wont work at all. Its a demo version of TMA. Perhaps not all the functions available for demo app.
Thank you for your comments.
Note : I am adding more Screenshots to show my TMA structure.
Can you get me the version? We should start with that then. I know some of us are still using pre-release version. That has known issues. Those issues were resolved in released version and I validated your specific use cases in my test instance. It looks good.
Hello Varanthan Ranganthan;
ThingWorx Version : 8.0.1-b39
ThingWorx App       : 8.0.0-0.0
Thank you.
Hi Murat,
That versioning should be fine - did you install the developer-kit version or the freemium version?
Milan
I have the same problem with "Status This Week" indicator.
I'm using KEPServerEX 6.2,
ThingworxManufacturingApps 8.0.0 (developer kit) and
DemoSimulatorPackage
Everything works properly only "Status This Week" indicator doesn't work.
Have you already solved this problem?
Stanislav
Greetings Stanislav,
Thank you for reaching out. We are unable to reproduce this problem, and would like to investigate further. I will contact you outside of this Community thread to arrange a time when we can work with you to troubleshoot this.
Best regards,
Steven M
Hello Ozgur,
Thank you for the update. Please feel free to start a new thread if any other questions arise.
Best regards,
Steven M
