Unable to import Thingworx Manufacturing app extension version 8.2.2
  • May 11, 2018
  • 2 replies
  • 3429 views
I am trying to import Thingworx Manufacturing app extension i.e. MED-61227-CD-082_SP2_ThingWorx-Manufacturing-Apps-8-2-2-extension-bundle into Thingworx composer. The version of thingworx composer is ThingWorx 8.0.9-b138. I am getting error as "Not Acceptable" when I click on import.
Please let me know what could be the issue.
Azim
Greetings Azim,
Please make sure you are having the same version of Manufacturing Apps and ThingWorx Composer to avoid such issues.
Himesh Rajpal
Hi @ahawaldar-2,
Manufacturing apps 8.2.2 version is not compatible with 8.0.9 ThingWorx Platform.
You need to import Manufacturing apps 8.2.2 on ThingWorx 8.2 platform version. These details are also mentioned in the ThingWorx Manufacturing Apps Setup and Configuration Guide
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
Himanshu
Hello @hchanana,
Now I am importing ThingWorx-Manufacturing-Apps-8-2-2-extension-bundle into Thingworx platform which is of version  8.2.2. But the import is unsuccessful. The error what I am seeing is
[L: ERROR] [O: E.c.t.w.ExtensionPackageUploader] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: Extension Exception][message: Extension must have a metadata.xml file.]
Can you please let me know what could be the issue?
Azim
Hello @hchanana@hrajpal,
OK, now here is the new update from my end. I was doing it wrongly while importing ThingWorx-Manufacturing-Apps-8-2-2-extension-bundle. I need to import separately, first ThingWorx-Manufacturing-Apps-8.2.2-00-extension-dependencies and then ThingWorx-Manufacturing-Apps-8.2.2-00-extension. While I was able to successfully import ThingWorx-Manufacturing-Apps-8.2.2-00-extension-dependencies but facing new issue while importing ThingWorx-Manufacturing-Apps-8.2.2-00-extension. This time I am getting error as below.
2018-05-13 21:08:54.894+0530 [L: WARN] [O: c.t.n.Menu] [I: ] [U: SuperUser] [S: ] [T: http-nio-8080-exec-7] Submenu PTC.SCA.SCO.ConsoleSubMenu in PTC.SCA.SCO.ConsoleMenu does not exist
2018-05-13 21:09:02.069+0530 [L: ERROR] [O: c.t.c.ImportProcessor] [I: ] [U: SuperUser] [S: ] [T: http-nio-8080-exec-7] Unable to process import: java.lang.NullPointerException
2018-05-13 21:09:02.080+0530 [L: ERROR] [O: c.t.e.u.ExtensionPackageUtilities] [I: ] [U: SuperUser] [S: ] [T: http-nio-8080-exec-7] Unable to delete SCO_Common-extension:8.2.2. This is likely due to other errors: ExtensionPackage SCO_Common-extension Does Not Exist
