11-Garnet
June 23, 2022
When displaying the DB Properties window some attributes cannot be seen well due to the text colors
  • June 23, 2022
  • 2 replies
  • 3414 views
When displaying the DB Properties window some attributes cannot be seen well due to the text color. Some texts/attributes in the window are shown in grey color and the background color is almost similar.
Now we need to do a "Edit" to see the details clear instead of just look to the fields.
+1 on this one! please make it possible to adjust the colour! or adjust the colour so it is readable!
VladimirN24-Ruby IIIAnswer
8-Gravel
February 5, 2023
If you're familar with Model Manager java customization, you may extend ColumnTypeAttributeEditor to your own overwriting getJComponent to setBackground any color you want (ex: Color.WHITE). Then you add your custom editor to your attributes in custom.xml.
KevinDe11-GarnetAuthor
11-Garnet
February 6, 2023
Hello Louis,
We are familiar with Java customizations but would like to have the customizations as low as possible. For this, i made this Product Enhancement because this is something that needs to be correct in a OOTB situation.
I want to thank you for this solution, we will enhance our customization with this BUT PTC should set this correct from the beginning 😉
Thanks!
Kevin
I completely agree Kevin; but PTC fixes are slow to arrive (even when we provide them with solutions). Take it as just a workaround.
