3D Acces render module - Result too dark
  • January 8, 2014
  • 0 replies
  • 1308 views
I am working with the 3D Access and the built in render module. When I render something the resulting image is always way too dark. Any ideas why that might be?
I attaches some pictures of the model. One in normal view, one with the lighting added to the scene, and one with the result of the render. I used the following lighting "light studio/object/high contrast/keylight, spot, 2 fill lights and back light" (might actually be named different. translated from german).
I am using "Creo Elements/Direct 3D Access (x64 edition) Revision 17.0"
