Can 20.3 Version save 20.1 file version?
  • January 16, 2021
  • 5 replies
  • 6207 views
If I have Creo Elements Direct 20.3, can I set 20.1 as default file version?
    Best answer by lfortner
    Hello Kaji,
    From 20.0, PTC changed the release naming. They treated the version decimal point not as a minor release, but as a major release.
    18.1 is an important but minor release of 18.0
    20.0, 20.1, 20.2 and 20.3 are treated as major release respectively (see PTC article  CS233356)
    Then:
    18.1 saves back to 17.0
    19.0 saves back to 18.0
    20.0 saves back to 19.0
    20.1 saves back to 20.0
    20.2 saves back to 20.1
    20.3 saves back to 20.2
    Hope this help
    I'm afraid you cannot do it straight forward. Modeling support just 1 major version back.
    From Modeling 20.3, save your model with version 20.2 and from a modeling 20.2 save it to version 20.1.
    Kaji1-VisitorAuthor
    Maybe you are right, but I remember that before the 20.1 (I don't know 20.0)  it was possible save two version back: from the 19.0 to 18.1 and 18.0 , from the 18.1 to 18.0 and 17.50 etc etc.
    So I hope the same for te 20.3 version.
    lfortner14-AlexandriteAnswer
    Hello Kaji,
    Then:
    Hope this help
    You can force a save backwards, but not in Model Manager
    This works if you know the release.  For example, the command below will set Creo to save to version 19.0.
    (bin-io-revision :MR-19-RELEASE)
    Regards
    Tom
    Perfectly right.
    Basically, CED can store almost all old versions by using the (secret) primitive:
    (bin-io-revision :SOME-RELEASE)
    However, when using PDM (MM? WGM?), this setting overwritten (reset) any time
    you save data to the database. You can only use the option to save "one version backwards".
    I assume you are running in "mixed CED environment"  (CED 20.3 and CED 20.1 using a common DB).
    Are you using a "Part Library" for creating standard parts (screws, bolts etc.)?
    If yes, it can happen that a user running CED 20.3 silently creates a new standard part in the DB.
    and users running CED 20.1 have no chance to use this library part (and it is very hard to get rid
    of such a library part in case that it is being used in an assembly).
    Kaji1-VisitorAuthor
    Thanks for the answer but this is a problem for me, I've to use PDM.
    A question I have similar to this.  Can Modeling 20.3 save to 20.1 Model Manager?
    Tom
    not possible with OOTB Model Manager as described already.
    the ideal solution would be to get this from PTC.
    Alternatives are possible, but at significant cost (consulting, customization).
    有没有Creo Elements Direct Modeling 20.6.1 的文件和许可证
    有一种高版本转低版本的lisp
