Costumize construction lines
  • November 2, 2022
  • 2 replies
  • 1369 views
When i select the infinite horizontal construction line from the ribbon, the construction line automatically snaps on the part edges as you can see in the 1st pic bellow.
But when i add a shortcut for the construction lines, and select the same command, the line doesn't snaps anymore (2nd pic bellow).
I don't know if someone can help me, I'm new at this software .
Thanks.
Best answer by highway45
You have to take the shortcut from the list "2D-Copilot" and not from "Construction Lines".
Unfortunately the symbols are the same.
highway4513-AquamarineAnswer
As a workaround, on the catch bar, select "Part" and "Default 2D"
