May somebody have a quick look at this?
  • December 25, 2013
  • 4 replies
  • 7376 views
Hi
I'm lost. I have 2 Workplanes and i would like to create a solid.
Thank you very much
Andy
Best answer by FriedhelmK
Hello Andreas,
yes you could use the loft funktion .
Have a look at the example.
Create the different workplanes and the geometry
Pay attention that the contours have the same number of vertex points
Create from the workplanes a workplane set
Create the match line
Create the loft.
This is described also in the help
Best regards
That's not very easy in Modeling/Express. You only can use extruding functions.
In full version you have some more possibilities with loft and/or surfaces.
As first steps you perhaps should extrude one workplane and then remove some forms with the other workplane direction. After that finishing the details.
Thank's. I think you have all functions as with full version, at least i can see also loft and surfaces functions
Hello Andreas,
Create the loft.
Best regards
Another short question.
How can i create a workplane that is perpendicular to another workplane? (And on the position on the line of the other workplane)
An example would be great
Andy
Hi Andy,
I think the pictures will explain it to you
But in reality it is more convenient to copy the existing work plane and to rotate it with the Pole Star 90 °.
I really appreciate your help Friedhelm. Thank you very much!
Andy
Hi
Thank's to Ferdinand's help i managed one part lofting my model.
I have dificulties to loft my head of my modell. I also tried a "Basic sweep" but the result is not what i have expected.
What i want is that the Matchline ML follows a particular line on another Workplane WP (here W2 on the attachment)... Or i'm completely wrong to solve my head with a loft?
Thank's for all the help
Hello Andy,
If you want to follow this contour you need to start just from this workplane.
I have copied the workplane w2 three times and adjusted the geometry approximately with scale to the predetermined shapes of s1.
The inner contour must also be provided with a Matchline
Wow! Thank you Friedhelm. Exactly what i wanted to have.
Thank you very very much
Andy
