symbols to text
AR
11-Garnet
11-Garnet
symbols to text
Is it possible in annotation to convert the symbols created as BOM position indicator into texts?
Because in this way they are not editable after having created them on the drawing, not even as characteristics!
Are you using the BOM module in Model Manager? If so, you can renumber the parts in Model Manager and then click Manage in the insert tab and update the balloons automatically.
Creo Element\Direct Modeling 20.6.0.0.0
memyself
(To:AR)
There does exist the command "am_pos_chg_no"  --  in UI: Pos Flags -> "BOM change Position Number. "  This command has the advantage that the BOM number is not only changed in the BOM position indicator itself, but also in the BOM table placed in the drawing acoordingly.
● PE6+8@home ● W10 Pro Build19045.3448 ● Drafting V20.1-5 ● Modeling V20.1-5
